Problem with Rear View Mode - Z2
By MCrager · Nov 29, 2008in Problems/Troubleshooting💬 4 posts👁️ 676 views
Posted Nov 29, 2008 · 04:05 UTC#1
Hi:
I'm having a problem with the Rear View Mode on my Z2, there's nothing displayed from the camera - just a black screen next to the map.
I've read the manual, and tried all the settings I could find. The camera is working, and I figure the camera settings are correct, because when I go into reverse, I get the reverse camera image.
I'd appreciate any help.
Craig
Posted Nov 29, 2008 · 04:33 UTC#2
You need to hook the red wire for the camera up to accessory power, not the reverse wire of your car
Posted Nov 29, 2008 · 05:27 UTC#3
Thanks for the reply.
So, the camera will work for reverse purposes, OR trailer monitoring purposes (in Rear View Mode), but not both?
Craig
Posted Nov 29, 2008 · 05:43 UTC#4
Craig
Never mind, I think I got it. The camera is currently only being powered by the reverse circuit. So..., I need to run the camera to accessory power (as you said), AND keep the head unit connected to the reverse circuit.
Thanks again!
Craig
