XM Radio and Ipod Problems
By F150 Duke · Sep 20, 2006in General💬 1 posts👁️ 678 views
Posted Sep 20, 2006 · 19:54 UTC#1
Hey Guys,
So while sorting out my OEM sub to Z1 problem for the thousandth time (which I think it ended up being a bad metra harness, we'll see if this fixes it), I decided to slowly take apart and check all my connections on the Z1 harness itself.
Well after putting it all back together I discovered my XM radio, XM navtraffic and IPod stuff doesn't work!
Then I saw that I forgot to ground the wire for those two items.
So I grounded the wire and it still won't work! I have both of them running their yellow battery wires to the yellow batter wire on my metra harness that plugs from the z1 to the OEM harness.
So my question is, could I have blown the fuse for the Ipod controls and the xm when I had the yellow wire attached, but not the ground wire? I'm talking about the fuses that run inline on the yellow wires.
I'm trying to figure this one out and am getting really tired of having to do break fix stuff on this project. I should have just left well enough alone.
Duke
