F900BT will not boot, stuck on "Caution" screen
By digires · Dec 02, 2008in Problems/Troubleshooting💬 7 posts👁️ 4,656 views
Posted Dec 02, 2008 · 02:29 UTC#1
Greetings,
I searched the forum in vain for an answer to this:
After 4 months of working relatively well, my F900BT began malfunctioning today. Basically, the language switched from English to Czech all by itself, and on startup began showing a black screen with a message in Czech.
Somehow (by hitting the map button and resetting several times) I was able to get back in and switch the language back to English. Shortly after I did this, however, on startup the screen would again show up black, with the words "Caution: screen image may appear reversed" at the top of the screen. No matter what I do now, I cannot get it to budge from this screen.
Does anyone know how to completely reset the software or otherwise restore the factory settings?
Thanks,
John
Posted Dec 02, 2008 · 10:23 UTC#2
"Caution: screen image may appear reversed" at the top means that the rear camera is selected. Since you don't recognize this screen, you probably don't have a rear-view camera installed.
The reverse wire is somehow connecting to ground (or 12V, depending on the setting). Check the violet/white wire.
-Eric
Posted Dec 02, 2008 · 15:10 UTC#3
Thanks for your response. It appears that somehow the backup camera functionality was turned on, though no camera is present. After waiting at the black screen for several minutes (presumably for the unit to go through the entire boot sequence) I was able to access the settings panel and turn off the backup camera function. All appears to be ok now.
*VERY* odd that this all happened randomly.
John
Posted Dec 03, 2008 · 13:54 UTC#4
John
you probably hooked up the reverse input to your ACC or ground or something ridiculous like tail lights or even headlights; go check your wiring.
Posted Dec 03, 2008 · 20:07 UTC#5
Hmmm,
Do you have kids? Have they been in the vehicle recnetly?
John
Posted Feb 07, 2009 · 22:28 UTC#6
John
THANK GOD YOU POSTED THIS!!!!!!
The very same thing happened to me when I did the 2.0 firmware update, so I thought it was because of that. I turned off my backup camera (I don't have one) and now everything works again! THANK YOU!
Posted Mar 16, 2009 · 00:58 UTC#7
THANK YOU! I spent 4 hours trying to fix this problem today. My screen came up in French. If it wasn't for this post I would have spent many more useless hours disconecting the unit and sending it back to Pioneer. What a relief!
