Hey everyone. I have a F90BT and my install looks pretty stock except for the GPS receiver. I couldn't route it well, since I did not want to remove the bigger dashboard panel (the one that has passenger-side airbag under it). So I have a wire going from the panel above my radio to the gps receiver near the windshield. I tried hiding the receiver in the glove compartment and right above the radio under the dash, but I noticed the gps signal losing strength - I had the unit running and i saw the reception strength lines going from green to yellow/red.
I realized that i might actually be able to use a bluetooth receiver instead of the stock one. I have a very good bluetooth receiver from my pre-Avic days. If I boot into WinCE, go to Settings and set up External GPS, I should be able to connect the two. In My Flash Disk\APL2\iGo, there are several sys*.txt files that have gps settings:
[gps]
port=7
baud=9600
default_latitude="34.05116"
default_longitude="-118.24258"
so i can adjust the port, in case I can't set it to port 7 by default.
Ideas? Do you guys think it's possible/probable that this would work?
Also, has anyone successfully hidden the gps receiver under a dash without losing much signal strength?
