CD-BTB200 Bluetooth – How to perform different BT functions?
By USRobo · Dec 04, 2008in General💬 4 posts👁️ 986 views
Posted Dec 04, 2008 · 02:03 UTC#1
I have the Blackberry Curve (Sprint) and it auto connects every time however the BT Audio connects sometimes and when it does I can't get the audio player to work. How do you load the songs and start BT Audio to work?
By the way when BT Audio connects I get both A2DP and AVRCP but nothing works or I don’t know how to get audio music to play. Why does the BT Phone connect and the BT Audio is not connected?
I was also able to transfer my phone and using the Category functions within phone so only the select categories were transferred to the D3. There is a nice guide in the BT Compatibility thread.
Another questions. How do we get the D3 phone ringer to ring louder? Mine rings very softly and the only option seems to be on or off.
Lastly does anyone know how to answer the phone only/disconnect from the D3 BT when the phone rings? Sometimes I don't want everyone in the car on the conversation when connect to the D3.
Thanks,
I posted a similar question in the BT Compatibility thread.
Posted Dec 04, 2008 · 03:21 UTC#2
1. to adjust the ringer volume, I have the sprint curve as well. you highlight the icon that looks like a speaker, there are 2 ways, first on the home screen, you move the mouse all the way to the top on the standard desktop, and then to the right, this will highlight the speaker icon, then you just click the right button and you will have different selections.
the second icon is located in the sub menu, from the home screen move the mouse all the way down and click to goto the sub-menu, then find the speaker icon and click the right button for options.
as for the d3, ok, I was never able to get it to auto connect to the bt as an A2DP player. I have been able to use it reliably by just pulling up the music player application and then clicking the left mouse button, there you will have the option to activate the bt connection to the d3. it doesnt seem to support controlling the player from the d3, I have to control it from the BB Curve. good luck.
Posted Dec 11, 2008 · 03:40 UTC#3
Followed your instructions and the BT Audio works perfectly and sounds great. And just like yours the D3 does not control the playback functions even though it has A2DP enabled. I have to control the playback function from the Blackberry Curve.
Still have a question about phone ring volume in the D3. I believe you described how to change the ringer volume in the phone and I want to change the ringer volume in the D3. My D3 rings very softly.
I'm really starting to like the D3 with the Bluetooth. Only problems are:
1. Can't switch from D3 to Phone after call connected.
2. If car is turned off/D3 turned off call is disconnected not switched to phone.
Anyone else experiencing these issues and have a solution???
Posted Dec 11, 2008 · 14:25 UTC#4
If you bring up the menu on the phone during your call there should be an option to "Activate Handset" or something like that. This will let you use your handest. If you also do this before you turn the car off, you should not lose your call connection.
