Wiring Harness for Mk5 Volkswagen? F90BT
By e39m5 · Dec 06, 2008in General💬 17 posts👁️ 4,265 views
Posted Dec 06, 2008 · 21:37 UTC#1
I drive a 2008 VW GLI
From what I've gathered, I need to buy (or fashion?) something that allows me to attach my F90BT to the OEM wires. Also, I think I saw that the RCA outputs should not be used. Is that correct? What do I use?
Does anyone have any information on this? What can I expect when I pull out the OEM radio?
Thanks,
e39m5
Posted Dec 09, 2008 · 22:25 UTC#3
The complete parts list is as follows:
PAC# C2R-VW (OEM Wiring Interface)
PAC# SWI-PS (Steering Wheel Interface)
PAC# SWI-CAN (CAN BUS Interface)
Metra# 40-EU55 (Antenna Adapter)
American International# VW-K1017 (Dash Installation Kit)
I used all of these on my MkV GTI with zero issues. Everything is available on enfigcarstereo.com and they have extremely quick turnaround.
Posted Jun 18, 2009 · 23:49 UTC#4
If one has a VW MKV with the multi function steering wheel, will the phone call buttons work to activate/deactivate calls as well as raise and lower the calls volume?
Posted Jun 19, 2009 · 02:36 UTC#6
DO NOT consider using any other harness besides the Connects2 harness. It allows OEM-like integration, requires no programming, and is smaller and cheaper than the PAC stuff. Trust me, you will LOVE it! :D
Posted Jun 19, 2009 · 02:59 UTC#7
only thing you dont get is the phone button working but that is not really a big deal
Posted Jun 19, 2009 · 03:29 UTC#8
+1 on the connects2. Works like an absolute charm (the one issue is that up/down seeks rather that scrolls through your presets) but otherwise you keep all your OEM functions. They also have a fascia kit that is probably the best fit for a mass marketed unit.
This is what I bought and what it looks like:
http://www.golfmkv.com/forums/showthrea ... ic-f7010bt
HR
Posted Jun 19, 2009 · 11:22 UTC#9
Looks like the crude PDF shows that the phone button does work?
Thanks for the tips guys!
Shawn
Posted Jun 19, 2009 · 12:36 UTC#10
http://caraudiosecurity.com
that is why you need. i know they show the phone button working. there is no support from pioneer for it. you have to cut and solder connections on it unless you can find those connectors. not hard though
Posted Jun 19, 2009 · 12:46 UTC#11
Oh, something else I just thought of! Seeing that adapter photos makes me think you can make the VW microphone work with the Pioneer unit?
Can't wait to get my new TDI this weekend!!
Posted Jun 19, 2009 · 18:41 UTC#12
is your tdi coming with steering controls because mine didnt, i didnt even have the option for it. because of this i just opted for a generic $10 harness to connect power and speakers.
Posted Jun 19, 2009 · 18:54 UTC#13
Sportswagens don't come with the MFSW, while sedans ALL come with them. You can add the MSFW to your sportswagen though.
Shawn
Posted Jun 20, 2009 · 01:41 UTC#14
I have an 06 Jetta TDI with an F700BT installed and I can offer an antenna placement suggestion. Put it behind the instrument cluster. Just above the steering column, remove the bellows by pulling the plastic trim piece at the bottom of the cluster straight out. It will uncover two T15 Torx screws. Remove them and pull the cluster straight out. The cluster plugs into a socket attached to a metal bracket. You can place your antennas on that bracket as it is steel and will hold using the magnets in the bracket. The antennas will have excellent sky exposure and work very well for me. Plus, its a very easy install. I may be able to dig up a couple diagrams if you are interested and need them.
Charlie
Posted Jun 21, 2009 · 02:40 UTC#15
ah, i didnt know the sedans came with it, seems very odd to me that one would and one wouldnt since they are practically the same car :)
Posted Jun 25, 2009 · 03:03 UTC#16
Wow, the connect2 stuff looks really nice. I wish I used that instead of PAC.
Posted Jun 25, 2009 · 10:31 UTC#17
i found it right before i i bought the pac stuff. i am so glad i did. also you dont need steering wheel controls to use this. either way it is cheaper than all the other stuff
