equinn2823 said:
i just got my z1 installed today and i think my installer did not hook it up the right way for the bypass. my manufacture date is march 06. if i have my e brake on everything works fine, if i try the headlight flash should my ebrake be on or off?? if they grounded my ebrake wire when they shouldnt have that would cause the bypass not to work correct? thanks in advance for the help.
If something changes when you put on your parking brake then most likely they didn't permanently ground it.
For the flashing bypass, you want the parking brake OFF. Or hit MENU - SETTINGS - HARDWARE - CONNECTIONS STATUS.
Look at the parking brake line, does it change when you apply the parking brake? If so then it's fine. Just make sure the parking brake is off and flash the lights. If it is ON all the time then flashing won't work till you unground that. And you will get an error eventually when you start driving around.
