Posted Sep 22, 2006 · 03:35 UTC#1
direct techs says it is purple/red behind glove box at ECU pin 8. or on back of fuse box 4 pin plug pin 1. but the relay vid bypass that my friend bought only works for about 4 minutes then give me the cant view in front seat crap. the vid bypass is just a couple relays that give the unit ground on parking brake and cut the vss wire. to make the unit think that it isnt moving. i think that this will not work with the Z1 but the online dudes say i should have no problem with it. i have 5 years experience and the vss wire looks correct on the screen. question though does the speed pulse actually make an audio sound on the Z1? or just give you numbers.
