AVIC d3 navigation help
By RSXJATT · Dec 08, 2008in General💬 5 posts👁️ 1,223 views
Posted Dec 08, 2008 · 00:34 UTC#1
Hey guys i have downloaded the CMT80 East DVD... burned it and when i inserted it in the D3 it did all the updates and worked fine, but my gps does not work....I am located in NEW YORK, QUeens...and the gps shows Los Angeles.... am i doing something wrong?
I bought the D3 off ebay and the guy didn't have the map dvd or gps atenna...i bought an Trimble gps antenna off ebay also. thanks
ALSO MY DVD'S DONT WORK... IT PLAYS THE SOUND BUT NO VIDEO SHOWS.... THIS IS EVE IF THE CAR IS PARKED...
THANKS FOR YOUR HELP
Posted Dec 08, 2008 · 16:13 UTC#2
Did the GPS work prior to the update? If so I would try resetting your D3 then go through the GPS menu and there's an option to check connection, make sure you're getting good reception. Check your antenna connection also.
Posted Dec 09, 2008 · 02:31 UTC#3
how can i reset the D3? thank you
Posted Dec 09, 2008 · 05:03 UTC#4
There's a small hole on the face of your unit just right of the disk eject button, this is the reset button. Take something with a fine point such as a pen and gently push it into this hole. This will reset your unit.
Posted Dec 12, 2008 · 03:41 UTC#5
ok i got it to track me down...but for somee reason neither can i select (go to destination) and all i cud do is track where i am its not allowing me to 6even change the time which is wrong...its the time where the gps was before los angles...now im in ny...thanks
