Jetta 2009 Center Console Removal
By rvega · Dec 09, 2008in General💬 8 posts👁️ 2,758 views
Posted Dec 09, 2008 · 15:30 UTC#1
Hey Everyone:
I searched the forums for info on this topic; no luck!
Doe anyone know how to take apart the center console to run all my wires (BT, Backup Camera, AMP, Speakers and such) to the trunk? :(
Posted Dec 09, 2008 · 16:40 UTC#2
Crow bar and a 5 lb. sledge hammer.
Unless you want to be able to put it back together....
:lol:
Posted Dec 10, 2008 · 03:22 UTC#3
I ran the wires in my 09 Jetta down the side. I'd remove the trip in the doors and run back that way. If you go through the center console you will have exposed wires between the console and the back seat.
Its a lot easier if you have some panel tools. I used a set I got on amazon for $15. It can be done without as well. The panels are tight but they aren't too bad to open. Have you already taken the dash apart?
If not I can try to dig up the instructions again.
Posted Dec 10, 2008 · 18:22 UTC#4
Yes; I took it all apart. Put in an AVICF90BT (loving it); Ipod; SAT Tuner (sirius). Getting ready to run wires for BT mic, AMP, also a SAT cable extension (so I can use factory shark fin) and backup cam.
I was thinking about going under the carpet to get to the console. That may be easier for me to get the USB connection and/or Ipod connection to the original location.
Hey thanks for the help!
Posted Dec 10, 2008 · 18:25 UTC#5
Cool. I have my sat radio module in the trunk wher ethe sirius module was so it can use the antenna connection. Backup camera I ran down the side.
My ipod is currently running under the side of the console and comes out next to the pass seat so I can use it for my iPhone.
If you end up running yours into the console I'd love to hear about it or see a pic. I may end up doing that at some point.
I just finished putting the whole car back together as I installed the amp and ran all those wires yesterday.
Posted Dec 10, 2008 · 18:40 UTC#6
How did you manage that? The IP-Bus cable is but 4 feet long?
I think I might do it this weekend. I can post some pics for sure!
Posted Dec 10, 2008 · 20:17 UTC#7
There is a 25 ft cable for sale; I used one so that all my components go in the trunk rather than trying to squeeze 50lbs of crap into a 20lb sack
Posted Dec 10, 2008 · 20:18 UTC#8
the cabel for my xm module was much longer than that. I have installed 5 of these so far in our cars and a few friends and they have all come with the longer cable.
I just ran it right to the back.
Maybe the Sirius tuner comes with a shorter ipbus cable.
