Z1 in a Hummer H1
By jimmy303 · Sep 22, 2006in Vehicle Specific Wiring💬 6 posts👁️ 1,932 views
Posted Sep 22, 2006 · 14:32 UTC#1
Anyone out there have the wiring for a 2002 Hummer H1 with the Monsoon system? Audio, VSS, etc? I am not looking forward to this, I have to move the A/C controls, some guages, build a bezel out of carbon fiber because the trim is carbon inside, extend harnesses, - I am gonna need a few beers tonight!!!!!
Posted Sep 22, 2006 · 21:54 UTC#2
I might suggest you post the same question on the elcova Hummer forum under the H1 topics. It might help...
http://www.elcovaforums.com/forums/
Posted Sep 23, 2006 · 18:37 UTC#3
OK, I got it all figgered out. The system uses a VW harness. VSS is one of two yellow wires behind the speedo. The other yellow wire is for the tach (good for remote start). The amp does not have a turn on lead, instead turning on when it see signal on the speaker leads, like the old school power boosters......
Posted Oct 21, 2006 · 17:42 UTC#4
The reverse lights are a nightmare to get to, considering the whole belly of the H1 is armored or covered by a cage, so I just put the reverse lead to a switch.
Posted Nov 09, 2006 · 22:49 UTC#5
Pics of the z1 in the H1...Please
Posted Nov 10, 2006 · 19:37 UTC#6
As soon as I can.....
