Restoring Z3 image to drive question?
By Agro · Dec 10, 2008in General💬 5 posts👁️ 782 views
Posted Dec 10, 2008 · 18:31 UTC#1
I have a Z1 and when I went to the Z2 I downloaded the .IMG file and using a friends computer who has PATA (I only have SATA) I was able to restore it and upgrade to a Z2.
I now have the Z3 image and I want to do the same, but I don't have access to an older PC with PATA. I do however have access to a PCI PATA card. I wonder if this will work?
The reason why it won't work using a USB -> PATA adapter is because the unlocking software cannot read the drive right? So if you had a brand new drive, you wouldn't have this limitation? I wonder if the unlocking software would read the drive if it was connected to the PCI card?
Posted Dec 10, 2008 · 19:37 UTC#2
If you upgraded your Z1 to a Z2, did you disable the security after unlocking it? If so, then the drive will still be unlocked, and you can use a USB to PATA to reimage the drive.
The drive unlock sofware will read the drive if installed on a PATA PCI card, but you may not be able to disable the security. It just depends on the PC.
Posted Dec 10, 2008 · 19:55 UTC#3
I bought a new 60GB Toshiba drive from NewEgg.com when I did the Z1 -> Z2. I would imagine it is locked again, but maybe the security part is not there?
Posted Dec 10, 2008 · 20:18 UTC#4
It's there unless you specifically disabled it. The drive will need to be unlocked before it can be upgraded.
Posted Dec 10, 2008 · 21:15 UTC#5
I figured I would have to use that website where they charge like $5 or something to unlock the drive. You don't keep any of the data, but I don't care about that. I am just concerned that using the PCI card I may or may not be able to read the drive and perform the unlock. I guess I'll give it a try...
