Upgraded from F700 to F900....
By dr.ona · Dec 10, 2008in Hacks/Mods💬 4 posts👁️ 1,312 views
Posted Dec 10, 2008 · 22:00 UTC#1
Ok...just did my first hardwire bypass and everything went great!
I originally bought a F700 and I decided to upgrade to the F900 for the video capabilities.
I wasn't sure if I would be able to use the existing F700 wiring harness. I was. The only difference between the F700 harness and the F900 harness are the following...
1) The F900 has the pink wire for the VSS. I removed it from the new harness and installed it in the appropriate empty slot on the existing harness.
2) The F900 harness also has a RCA rear monitor output wire...the F700 doesn't.
Robert
Posted Dec 11, 2008 · 12:46 UTC#2
No way f900 can play dvd and f700 only can play cd .
Posted Dec 11, 2008 · 14:49 UTC#3
That has nothing to do with the differences in the harnesses. Re-read the OP. It is only talking about harness differences, not over-all differences between the units.
Posted Dec 11, 2008 · 15:34 UTC#4
He's not asking a question. He's contributing guidance to others who may want to do a similar upgrade and suggesting you can keep the f700 harness in place if you just move a couple of wires around.
@ OP: Well done.
--Mav
