bypass problems
By shanekhan · Dec 11, 2008in Hacks/Mods💬 6 posts👁️ 1,500 views
Posted Dec 11, 2008 · 02:19 UTC#1
i just had my avic 900bt installed in a 2009 civic they installer did the wire by pass but i still cannot watch dvd while in motion gettin the message cannto plaback while in motion stricly prohibbted installer said he did everything right what shud i do?
Posted Dec 11, 2008 · 02:35 UTC#2
He didn't do everything right...so however you would deal with that is what you should do...
--Mav
Posted Dec 11, 2008 · 02:42 UTC#3
see the thing is it works for about 202-5 seconds then cuts out then works really fustrating anything anyonre suggests?
Posted Dec 11, 2008 · 02:45 UTC#4
I'm not being "smart" with that response. Do a search and you'll see this issue has been reported when the bypass is incorrectly performed. I was just trying to help you cut to the chase...which is...the bypass was performed incorrectly. The fix for it is to have it done correctly. End of story.
Posted Dec 13, 2008 · 22:15 UTC#5
i got the same problem and i cant figure out how to fix it, im an installer and have bypassed an older unit, but the other day i tried to do it on a 2.0 updated one and same problem as you
Posted Dec 13, 2008 · 22:27 UTC#6
Check your wiring
