Button Issues since making mods
By sy628109 · Dec 11, 2008in Problems/Troubleshooting💬 7 posts👁️ 1,176 views
Posted Dec 11, 2008 · 17:57 UTC#1
I have made a few mods; bypass and some changes to the navigatemap.ui file.....ever since doing so my touchscreen has been acting funky.
If I do not touch the screen for a few minutes the only way to get the touchscreen to work is to hit the map key and then go back to whatever I was trying to do. (almost like the map key is resetting the touchscreen) It could just be a coincidence that this is happening after the mods, afterall my girlfriend's D-series does the same thing.
Is anyone else having this problem, any ideas on how to fix it?
Posted Dec 15, 2008 · 16:35 UTC#2
I've narrowed this issue down, it seems the touchscreen does not work only after using the volume knob, regardless of the change up/down. At that point I must use one of the hard buttons (menu or map) to reset the touchscreen.
I ask this on here because Pioneer's support is pretty much useless, all they can tell me to do it reset the unit.
Posted Dec 21, 2008 · 18:06 UTC#3
i have the exact same problem, under the exact same situation. If the volume is adjusted, I completely lose the use of the touch screen, until I work back through from either the 2 buttons or moving the knob (not turning, but left/right or push)
its a real pita, thats for sure... the only change i'm made from factory was to load Maverickster's data.zip. Unfortunately, i never actually ran this unit without the modded data.zip, so I don't know if that has anything to do with it.
Posted Dec 21, 2008 · 19:06 UTC#4
not an issue with my unmodded unit...
Posted Dec 22, 2008 · 16:59 UTC#5
I don't have the problem and I used some of Maverickster's mods but not all. I didn't do the compass detour mod and Speedo/Altimeter/Route Info mod. I'm guessing it has something to do with the later. I'll take a look through the code but there's a lot there.
Question: Is your unit set to full screen cockpit?
Posted Dec 22, 2008 · 18:14 UTC#6
Same problem here... not using Mav's, but I am using a data.zip I modded myself. Seemed to just start happening out of the blue about two weeks ago... :?
Posted Dec 28, 2008 · 20:02 UTC#7
I figured mine out, it was the PAC steering wheel control module. Do you guys have that connected? If so disonnect it and perform all three resets. (1. nav menu-restore factory defaults 2. reset button 3. hold reset button and eject button for 10 seconds simultaneously)
The wires are still connected to my factory harness, I disconnected the blue box from the head unit and the PAC harness.
If that wouldn't have worked my only option according to Pioneer would have been sending it in as a defect.
Hopefully this works for you guys.
