Anyone with experience with install on a Touareg
By qhadge · Dec 12, 2008in Vehicle Specific Wiring💬 6 posts👁️ 1,134 views
Posted Dec 12, 2008 · 00:20 UTC#1
I have a 2004 Touareg with premium sound [sound 2] and want to install an AVIC-f90bt. I thought it would be pretty straight forward but I am getting bad info on the net. Some say that this will be a plug and play install, others say that you need to create a custom crossover.
Does anyone out there have any expereince with installing an AVIC to this car? :?:
Thank you in advance
Posted Dec 12, 2008 · 01:24 UTC#2
What the hell is a Touareg ?
Posted Dec 12, 2008 · 01:29 UTC#3
It's a VW SUV.
Posted Dec 13, 2008 · 08:06 UTC#4
if i recall u have to bypass factory amp because OEM amp is triggered from the databus system to turn on and off, so with aftermarket radio no way to switch it on and off
Posted Dec 15, 2008 · 03:25 UTC#5
Wow, does that means I am going to have to set up a custom passive crossover solution. 11 speaker system. :shock:
I was hoping could just use a line output converter and plug into the factory harness.
Posted Dec 16, 2008 · 02:40 UTC#6
yeah gonna have to get an amp and or build crossovers
factory amp take a low level input the problem is turning it on
