Ive got all my harnesses connected, and had a questions. I have two blue wires that arent connected - antenna from
the metra harness, and the remote control antenna from the deck harness. Do these need to be connected? Both are solid blue.
don't worry about it. if you don't know what they go to, you don't need them.
haha, if you have a powered fm antenna embeded in yoru window your going to wonder why you can't get reception for MSN direct or your FM stereo.
The blue wire is what tells the fm power antenna booster to turn on in your car. but if you don't have this, and your factory harness adapter did't say connect blue wire here, then you may be fine.
well its going in my 350Z and ive got an external antenna
