STARTUP PICTURE ON D2
By yothai · Sep 23, 2006in Hacks/Mods💬 16 posts👁️ 7,789 views
Posted Sep 23, 2006 · 15:22 UTC#1
can anyone please show me how to change the startup screen on the D2?
THANKS A A BUNCH!!!
Posted Sep 23, 2006 · 20:06 UTC#3
I take it you rename BGOPEN2.JPG to your picture then put it back on the disc....
However, my question is...
Do I need to run my own custom DVD +R DL disc the whole time to retain the loading graphic or does it load it into memory, where I then can put the original pioneer disc back in.
Bennett
Posted Mar 17, 2007 · 15:56 UTC#4
I followed the guide from the above post and I have been searching as well....All I want to do is update the startup graphic. The alternate disc I made worked fine as a backup the process that is in the post is flawless and I got it to work the first time (as a backup disc) but it doesn't change the startup screen. I think you have to reset the unit as if it were new and reload the new burned disc for it to work. But I dunno thats what I think, I don't want to lose all my information that I have stored just to change the startup graphic.
Posted Mar 17, 2007 · 16:11 UTC#5
Sorry to post again so shortly after the first but I did more searching (patience is a virtue) and I did find out that all you have to do (if you properly burned the disc) is hit the reset button under the directional knob and your custom startup screen will appear! I am now enjoying my custom graphic.
P.S. you will not lose your memory i.e. your address book, or 3D calibration just your recent destinations will be gone.
matt
Posted May 06, 2007 · 08:10 UTC#6
still lost... been looking for hours it seems to find how to change the "startup"/"boot"/"loading" image. a question for it is in one of the BG DIY's but i could not find an answer. this thread is kinda ambigous too...
surely, this must be simple. anyone please? thanks.
Posted May 06, 2007 · 14:34 UTC#7
Just replace BGOPEN2.JPG with your own personal JPG. Then reset the unit.
If using a SL DVD, put the original disc back in.
Posted May 06, 2007 · 18:24 UTC#8
i've done that (replaced the BGOPEN2.JPG with my edited one) put the disc in and reset the unit, and it just gives me a blank screen... am i doing something wrong?
Posted May 06, 2007 · 23:29 UTC#9
Are you sure it's a .jpg with the correct resolution?
Posted May 06, 2007 · 23:38 UTC#10
yup.. 500x240 jpg.. i attached the pc that i used..
Posted May 07, 2007 · 00:08 UTC#11
Huh, I really don't know why it isn't working. It should...
Posted May 08, 2007 · 15:04 UTC#12
Make sure that the file name, and extension is in ALL CAPS. Apparently this makes a difference, at least in my D2. When I burned a copy of the disc, to add custom wallpapers, and the file name was in lowercase, the unit didn't see the files at all.
Posted May 15, 2007 · 05:31 UTC#13
I have the same problem. I did it the way I was told and it just doesnt work.
Posted Jun 17, 2007 · 02:21 UTC#14
same problem.. is the loading screen a .PIM file? I hate wasting these DL disk for trial and error. I spent $70 on a DL DVD burner just for this alone, so each disk is making this mod more and more expensive. Oh well atleast I got a nice external DL burner.. made by pioneer too, 10X burner for $70 cant beat that...
Posted Jul 08, 2007 · 05:19 UTC#15
Have you tried changing the name from BGOPEN2-2 to BGOPEN2. My avic wouldn't read disc with ( - ) when I was trying to set them up for background pics and maybe this is the problem that you are having.
I could be wrong, but it worked for my background images.
Posted Dec 10, 2007 · 03:39 UTC#16
ok.. i made a background, burned it on a SL disk with just the BG pic on it, reset it,, my pic showed up but as soon as i put the original nav disk in, it reset itself and loaded the pioneer one. Do i have to pretty much burn a back-up disk with the edited BG pic and use it all the time?
