Help AVH-P4000DVD
By kidder · Dec 15, 2008in Pioneer AVH Series💬 3 posts👁️ 2,173 views
Posted Dec 15, 2008 · 10:10 UTC#1
Can someone please confirm for me that I can run full rage off the rear speaker level outputs and a sub off the rear rca at the same time.
The userguide mentioned this when talking about setting the preamp out:
Both rear speaker lead outputs and RCA rear
output are switched simultaneously in this
setting.
SO I am confised and want to make sure before installing it.\
Kidder
Posted Dec 18, 2008 · 01:28 UTC#2
Yes you can
Posted May 28, 2009 · 14:34 UTC#3
Yes as long as your rear speakers are conencted along with your other car speakers it will have a range you set (High Pass Filter) you can set to send any sound levels of a certain level straight to your subs. You can also set the frequency of the subs. You have 2 controls one for your internal speakers and one for your subs along with the choice to turn the subs off completely.
It takes A LOT of time to fine tune your system to your liking so be prepared to spend countless hours having fun getting your neighbors pissed with the speakers turned up =)
