700bt freezes when trying to go into test mode
By bigdaddysmooth · Dec 16, 2008in Hacks/Mods💬 5 posts👁️ 1,417 views
Posted Dec 16, 2008 · 02:38 UTC#1
Hi-
Would you have any idea why my AVIC F700Bt freezes up when trying to enter test mode? I have test mode and MitaCap folders on the root of my SD card- it boots up, say's downloading files, and then as soon as i try to close the copy box as directed, the box turns bright green and just freezes up.
Thanks in advance,
Kevin
Posted Dec 16, 2008 · 03:03 UTC#2
You have to press the little X in the top right corner. Calibrate your screen if you never have yet, it helps a lot in TM
Posted Dec 16, 2008 · 04:37 UTC#3
I had the same problem. As CatchMe states, make sure you calibrate your screen before going into testmode... AND make sure you use your stylus.
Whenever I used my finger, my testmode froze. Stylus works every time.
Good luck
Posted Dec 16, 2008 · 22:13 UTC#4
How do you get to test mode?
Posted Dec 17, 2008 · 00:45 UTC#5
Wow dude you ROCK-
I used the stylus and BAM, even a newbie like me figured out the rest!
Thanks a million. I now have video at any speed, a voice nav mute button, compass button route delete, and much more!!!!!
This is going to make Modding easy now- much appreciated.
