FM Not working after Updating.
By alexbouza · Dec 16, 2008in Problems/Troubleshooting💬 10 posts👁️ 1,229 views
Posted Dec 16, 2008 · 05:25 UTC#1
Hey guys. I got a F90BT installed today in my GMC ENVOY XL 2003 BOSE AND ONSTAR.
I got HD radio in there. everything was working fine until I updated to 2.0. then My AM and FM radios inputs only give out static. but When I use HD radio imput, I can hear all the radios fine.
Is this bc the new firmware routes all the radios to the HD input if you have it? or something got messed up?
thanks a lot!
alex
Posted Dec 16, 2008 · 17:40 UTC#2
Update shouldn't/couldn't change FM settings. Could it be that the antenna came undone from the unit?
Does your MSN Direct still work (uses same antenna)?
Posted Dec 16, 2008 · 17:44 UTC#3
I haven't activated it yet.
But the thing is that right before the update it was working perfect. The second I did the update it stopped working.
HD Radio doesn't use the antenna? and like I said from HD radio I can listen to regular radios.
Posted Dec 16, 2008 · 18:02 UTC#4
HD radio has a different antenna input. It uses the same antenna on the car, but the installer has to install a splitter so that the antenna can be hooked to both the HD radio module and the AM/FM radio receiver. It is possible that the cable to the AM/FM radio came loose, while the cable to the HD radio is still okay.
Are you sure that FM was really working before the update? Maybe the installer only connected the antenna to the HD radio?
Posted Dec 16, 2008 · 18:08 UTC#5
Yeah It was working perfectly. I messed around with it a lot before getting the update.
Oh well, it's not a big deal. Given that I more likely going to use the HD radio Connection. But I'm the kind of guy that likes everything operational you know?
So everybody agrees that it's the antenna? It's just weird, bc like I said it was working fine before the update.
:o(
Posted Dec 16, 2008 · 21:36 UTC#6
You could try doing a hard reset.
Posted Dec 16, 2008 · 21:37 UTC#7
How do I do that?
Posted Dec 16, 2008 · 22:42 UTC#8
next to your eject button to its left is a small detent,use a pen and press it down along with the eject button at the same time for 5 seconds.
then release and let your 900 reboot.
After the reboot all your settings are erased so you need to set all your presets ETC.make sure to turn on your ipod as well if you have it connected in your settings menu.
Posted Dec 16, 2008 · 23:58 UTC#9
Could this be my problem?
I Just activated MSN Direct. Doesn't seem to connect either. I reseted the unit (soft reset) when it turned back on It sayd MSN DIRECT CONNECTING. but nothing happened.
Could a hard reset help any of this?
Ale
PS: Im sorry and very thankfull to everyone that is helping me. but it is crazy the ammount of issues that i walked out of circuit city with!
Thanks again
Posted Dec 17, 2008 · 01:36 UTC#10
I concur with the poster above. The installer needed to install an antena splitter. The antenna needs to be connected to your head unit AND your HD unit.
