Apple composite vs component cables
By 916Kev · Dec 18, 2008in General💬 10 posts👁️ 1,735 views
Posted Dec 18, 2008 · 18:00 UTC#1
Which is the better cable? Anybody personally use them? How do they compare to the cable provided by Pioneer? All the features are available regardless of cable right? Thanks!
Posted Dec 18, 2008 · 19:15 UTC#2
With the pioneer cables, my ipod would cut out multiple times daily. I changed to the Apple cables and have not had my ipod cut out once.
Posted Dec 18, 2008 · 20:55 UTC#3
when u say cut out, what do you mean? are you saying the ipod would not be connected when u started the unit or when u were listening to the ipod it would cut in and out and speakers would go in and out?
Posted Dec 18, 2008 · 21:08 UTC#4
The pioneer doesn't have component inputs. You must get the composite apple cable or the pioneer equivalent.
Posted Dec 19, 2008 · 16:04 UTC#5
I have the Composite cable from Apple with my iPhone 3g. You have to hit "No" to airplane mode when you plug it in, but other than that... it works flawlessly. As stated, the unit does not have Component inputs.
Posted Dec 20, 2008 · 22:55 UTC#6
When my ipod would cut out...I would barely hit a bump, hear a chime from the AVIC, and then the ipod would stop playing and my F90 would switch to the off screen. I could keep driving, hit another bump, hear the chime again, and it starts playing like normal.
I have since switched out the cable for the Apple cables, and haven't had an issue since.(With the ipod).
Posted Dec 21, 2008 · 00:51 UTC#7
Yes the apple composite cable is the way to go, the build quality is second to none. It doesnt compare to the pioneer cable which looks like something made in a garage, and they tied it together using heat shrink tubing or something.
The composite cable is a single unified cable until they seperate at the end. Where as the pioneer cable seperate right out of the head of th eipod connection adapter.
I had issues myself where the iphone 3g wasn't charging and I had issues with controls and dropping out etc.
I looked at the inside of the adapter where the pins are and it looked warped, plastic was acutally different lengths where the pins were.
bought the new apple cable and have no issues. So, that is my own experience.
Posted Dec 21, 2008 · 00:59 UTC#8
In my case, the apple cable has been worse. There are some days, I cannot get the ipod to work through the unit. The workaround has been to change the AV1 setting from Ipod to video. Of course I cannot control the ipod but once I make that change, it never drops.
I am eventually going to put the Pioneer cable back in. While I am sure it will still drop, it was a lot more stable than with the apple cable I got it connected to right now.
FYI, I am using an IPOD 160GB classic.
Dave
