Using flash drive for iGo map data
By yoav · Dec 19, 2008in Hacks/Mods💬 3 posts👁️ 1,037 views
Posted Dec 19, 2008 · 22:02 UTC#1
I'm looking at sys.txt for iGo (the one that comes with the avic-f). It *seems* like there should be a way to set the location of the content directory... but I can't seem to figure out which it is...
Basically, I want to get a bunch more .dem and 3dl files for my local area and use them... but the flash drive seems pretty full.. I figured I can just use an SD card as the 'map source'.... can't I?
Posted Dec 20, 2008 · 00:00 UTC#2
It is possible you just need to write a line of code to look for the sd card for the content. Now the actual code you need I have no clue but im sure Boris or someone else more knowledgeable will chime in.
Posted Dec 20, 2008 · 01:56 UTC#3
i think the line is something like
[folders]
app="%SDCARD%/Content"
