Hi all: i recently bought a refurb f90bt and after it was installed it would work fine if i was parked but when i started to drive it would reboot every 20-60 seconds. Keep in mind that it has never worked properly. The installer said the unit was probably defective. So i'm trying to fix it w/o sending it back. I followed the steps in the forum to reflashing, including backing up my igo folder. The reflash seemed to work ok and i copied back the igo folder. After shutting off and turning the car back on, the system came up to the language questions but i could not click on english or samantha, i only could hit OK. In the settings screen the NAV settings and system settings options are not clickable, just grayed out. I was able to listen to radio/sirius and ride around the block and the system did not reboot itself. This was a first so I think I am making progress, i hope.
Some info that might help: During the deleting of files from the Flash Drive, the system would not allow me to delete a subfolder that was in the user folder(i think it was userdata, or system) the folder was full of files that just looked like garbage. I could not delete or rename these files. During one of my reboots into test mode, I was able to rename the folder and it is still sitting under the user folder.
any help would be greatly appreciated. I am dying to get this thing working properly.
