If your unit reboots continously, or
reboots every few minutes, or
you can't access the navi settings menu,
here is an easy solution:
- Boot into test mode
Navigate to the 'My Flash Disk/USER/UserData/iGo/save' folder
Delete all files in the 'save' folder (there will prob be 4 files and 1 folder)
Navigate to the 'My Flash Disk/USER/UserData/SETUP' folder
Delete all files in the 'SETUP' folder (there will prob be 5 files)
Exit test mode and reboot normally
Problem solved!
(you will need to re-enter your settings)
Please post here and let me know if this solves your problem,
- I'm 99.99999% sure this will do the trick.
happy holidays!
infochia
