Voltage stabilizer help random reboot?
By AZFlyingDiver · Dec 21, 2008in Problems/Troubleshooting💬 3 posts👁️ 716 views
Posted Dec 21, 2008 · 05:29 UTC#1
OK - this may be obvious or stupid, but I'm trying to figure out which :)
Given the sometimes quirkiness of our WinCE-based units, would a voltage stabilizer maybe reduce random reboot (I'm talking about the occasional reboot - not the continual reboots, which are a different problem)?
Considering this:
"The function is to stabilize or filter an AC voltage from the alternator to get a clean DC voltage. A clean DC voltage is required for electronic equipment to operates in optimum condition."
Apparently, a voltage stabilizer can "smooth out" voltage - it's basically a capacitor setup. I'm thinking that weird, random reboot can happen when there's a very, very brief voltage drop while driving...
Here's the type of unit I'm talking about: http://eurobahnmotorsport.com/nrginnovations/nrgepacvoltage-stabilizer/g-53730.aspx
They seem to range around $75 or so...
Posted Dec 21, 2008 · 13:54 UTC#2
calling shennanigans ;)
your vehicle battery will (should) cover you for those times where you might get low voltage from the alternator at idle.. your device would be handy though for the times where there might be high voltage, in case the voltage regulator is fubar
Posted Dec 23, 2008 · 05:41 UTC#3
I think it's while starting the car that you have to worry about. There can be some big voltage drops while the starter is engaged.
