VSS location on a 1989 Ford Mustang 5.0
By Xtreme Inc. · Dec 21, 2008in Vehicle Specific Wiring💬 6 posts👁️ 3,140 views
Posted Dec 21, 2008 · 20:08 UTC#1
Is there anywhere I can catch the VSS wire on a 1989 Ford Mustang 5.0 liter instaead of going to the manual transmission? Could it be located in the instrument cluster? I think it is grey/black. I didn't find any info on the VSS site posted.
Posted Dec 21, 2008 · 20:19 UTC#2
This is what I found:
VSS Wire Gray/Black Wire Harness from Transmission
Pulses Per Mile 8000 PPM
Posted Dec 25, 2008 · 22:40 UTC#3
it is not in the dash, the speedo in dash is cable driven
either get it at the trans or at the cruise control module
Posted Dec 29, 2008 · 04:32 UTC#4
Where is the cruise control module at?
Posted Dec 29, 2008 · 15:27 UTC#5
Sorry to say that everyone who tried to help was wrong. I stayed up all night working in & under that car! Under @ the trans, there is NO Grey/Black wire @ the sending unit or anywhere else. I ended up obtaining a wiring diagram of an 88 model (which IS different) & matched up 1 plug off of the CCM (cruise control module), the wire colors & locations. The 2nd plug didn't match colors @ all, so I counted the plug's wires from the 88 Mustang & then did the same for my 89 & where there would be a grey/blk wire for the 87-88 model's, there was a GREEN/WHITE wire in the same location, so after testing & hooking up to it, guess what?>>>>>>>>>>>> Yep, IT WORKED!!
SO, for the record, the VSS wire on an 89 is @ the CCM (to the left of the clutch pedal) & it is GREEN/WHITE.
I appreciate the help.
I couldn't even find anyone who had the location of the CCM listed either.
Hard work & enough time is what it took. IT REALLY SUCKED!!!!!!! :lol::D
Posted Dec 31, 2008 · 05:42 UTC#6
maybe its not gray/black at sending unit but its deff available there
