ICON are greyed out
By waldo238 · Dec 22, 2008in Problems/Troubleshooting💬 6 posts👁️ 1,004 views
Posted Dec 22, 2008 · 14:03 UTC#1
Hello people I just installed my 700 and did the 2.0 upgrade to the unit and now some of the ICONs dont work such as any thing under phone, also system setup and NAVI setup. There is one thing that I think might be the problem is that I did forget to hook up the wire to the parking brake could this be my problem? Most everything else seems to work. if this is it then should I hook it up or do the mod to it, and which one hardware or software. Any help on this would be great if there is a proble then I will take it back to CC.
Posted Dec 22, 2008 · 14:53 UTC#2
Yeah, you definitely did not hook up the parking brake wire right. Navi and System settings are greyed out until you actually pull on the handbrake. If I were you, I'd do a hardware bypass in addition to software bypass. For hardware, you only need to ground the parking brake wire, and software bypass will take care of the rest.
Posted Dec 22, 2008 · 15:25 UTC#3
Would you happen to have the info and steps I need to take to complete this?
Posted Dec 22, 2008 · 21:06 UTC#4
Go to Hacks/Modifcations forum, its mentioned in one of the first posts in great detail / discussion.
Posted Dec 23, 2008 · 00:50 UTC#5
I did the hardware mod and all is good. What does the software part do for?
Posted Dec 23, 2008 · 04:33 UTC#6
For people that would rather hack software instead of take thirty seconds to move that wire
