Newbie needs Help.... Z1 not starting up any more
By sameolg · Dec 22, 2008in Problems/Troubleshooting💬 7 posts👁️ 703 views
Posted Dec 22, 2008 · 14:39 UTC#1
Hey everyone im new to this forum and found alot of usefull info so far. I just finished installing the z1 i got from a friend and was working perfectly untill this morning. When i turn the car on nothing comes up no lights, no boot up on the screen... I pulled the unit out and found theres power to the unit and the fan is kicking on.. Can someone please give me some helpfull feedback...Thanx
Posted Dec 23, 2008 · 13:58 UTC#2
Anyone......
Posted Dec 23, 2008 · 14:25 UTC#3
It could be a million things, but I would start with the basics and try to power up the unit on the work bench. Connect yellow and red wires to the '+' 12v source, and the black and light green wires to the '-' 12v source and see what happens. Verify that the inline fuses are good first.
Posted Dec 23, 2008 · 15:43 UTC#4
i just tried getting it working no good, the fan turns on only. As far as the inline fuses theres only 1 the yellow wire and its fine. Im tryin to avoid sending it out,possibly somethings wrong that i might be able to fix
Posted Dec 23, 2008 · 15:57 UTC#5
If the fan turns on, but nothing else happens, it sounds like you have a hardware issue and may need to send it in...
Posted Dec 23, 2008 · 16:38 UTC#6
^Ok, thanx for the info i'll just send it in.
Posted Jan 07, 2009 · 13:56 UTC#7
Just some updated info. Got word from pioneer today that there was corrosion on the circuit board which caused this problem... THanks for the help..
