no sound w/ bt
By timalec · Dec 23, 2008in Problems/Troubleshooting💬 12 posts👁️ 1,882 views
Posted Dec 23, 2008 · 01:22 UTC#1
I have a lg vx 9700 (dare) and everthing works except i can't hear the other line over any speaker. the mic works and everthing....did the installer forget something. I also had the same prob with my ipod classic....it reads everthing but no sound. ?????
Posted Dec 23, 2008 · 04:33 UTC#2
For your ipod, change AV input 1 to ipod like the manual says
Posted Dec 24, 2008 · 01:32 UTC#3
That's what it was on???
Posted Dec 24, 2008 · 18:11 UTC#4
Um, did you try turning up the volume? There are two differnet blue tooth volume sliders in the menu's consult the user manual to find them as I can't remember where they are at the top of my head. main menu, phone settings, volume or something
Posted Dec 24, 2008 · 18:22 UTC#5
menu, settings, phone, phone volume (after bluetooth is connected)
Posted Dec 28, 2008 · 07:01 UTC#6
I have this same problem. I have the volume on both turned up all the way. The same thing was happening with my navigation directions, but after I hooked a usb jump drive with songs on it the navi worked but still not sound out of the speakers for the phone. Can anyone help?
Posted Dec 28, 2008 · 23:13 UTC#7
If its not the user settings, then you hooked it up wrong or its a defective unit, it all comes down to that.
I didnt see, did you say the speakers do work all other times, just not bluetooth? Read the manual, double checka ll settings. Call pioneer up and ask them as well, you may have a defective unit.
Posted Dec 29, 2008 · 00:20 UTC#8
I have read that on Chrysler vechicles with Infinity sound system that you have to hook up the front speakers on the unit to the rear speakers going to the amp. Maybe I will try this and see if that works and if not I will call Pioneer.
Posted Jan 06, 2009 · 04:12 UTC#9
did you try it yet. i still haven't got it fixed. Also there is no sound when i hook the ipod up....but the ipod works on the screen. And i can't hear the nav talking...it just cuts out music
Posted Jan 16, 2009 · 14:21 UTC#10
ON the AV Source screen do you have AV1 set to iPod? If you reset the unit that switches back and you lose the audio signal but not the screen images.
I have a very similar problem with BT and Nav volman tho, I have such low volume on the BT as to make the phone unusable and the nav directions are inaudible. The overall volume on the unit is low as well.
I attributed this to the Bose speakers and amps in my car but I too am looking for a solution.
Did you hook the speakers up to the RCA jacks or the speaker wire coming out of the unit? I'm wondering if that may be the issue in my case. One set goes to speakers and one set is for a separate pre amp. The Bose system incorporates amps into the speakers and I went with the RCA jacks. Now I'm not so sure that was the right thing to do..
The other possibility I'm investigating is the settings on the Onstar/Bose module I needed to hook the unit to my GM wiring harness, but the volume of the Onstar connection is fine.
I'm calling Pioneer this morning to try and get a human on the phone and see if they can direct me.
Posted Jan 16, 2009 · 16:07 UTC#11
Blue/wht is amp remote turn on, not solid blue. Do you get sound when listening to a CD?
What kind of car?
Posted Jan 28, 2009 · 21:33 UTC#12
WOOW... after some search i finally find the exact same problems... just bumping this to see if anyone has a fix yet for this????
i havnt tried uploading a USB with sound but that sounds like a temp fix as well???? deffective units???? should i bother with submitting my unit back to pioneer for service/return????
