iPhone 3g
By guod · Dec 24, 2008in Problems/Troubleshooting💬 7 posts👁️ 1,256 views
Posted Dec 24, 2008 · 00:02 UTC#1
I have an iphone 3g and when I plug it into my avic-f700bt, i get the message on my phone saying that the accessory is not made for my iphone. I am using the Apple Ipod composite cable and the avic will control the music and all that but I am just concerned about the message. Does anyone else get this message?
Posted Dec 24, 2008 · 01:14 UTC#2
I get this message as well. I believe it is harmless.
The iPhone will still charge properly, but sometimes you may hear this weird buzzing on your radio (caused by the GSM signal in the phone). Newer accessories (made specially for the 3G) have some sort of shielding in order to reduce interference from the cell signal.
Posted Dec 24, 2008 · 02:41 UTC#3
Co Sign
I have an Iphone 3G and the Apple composite cable.
I get the same message.
Everything still works flawlessly. Phone charges, plays music and videos.
Youve got nothing to worry about.
Posted Dec 24, 2008 · 03:13 UTC#4
if it wasn't obvious, the answer is when it says "do you want to turn on aircraft mode?" the answer would be "no" since you want to phone to keep taking calls.. ( I can see that messing someone up if they don't think it through)
Posted Dec 24, 2008 · 12:27 UTC#5
I have no idea what it means, to be made to work with the iphone, my guess it has more to do with interference then anything else. Taht's why it asks immediately, do you want to put it in airplane mode, completely turning off all radio's. wifi, 3g, bluetooth and edge. That way you don't get all those electronic pop's hiss's and beeps when your phone is communicating with the network.
As far as does everyone get it, yes. Pushing yes, turns off all radios, pushing no just removes the message, do nothing it goes away on its own.
My iphone 3g charges, works fine with bluetooth, works fine iwth ipod control and video, so that message pretty much is a bug as far as im concerned.
Posted Mar 04, 2009 · 04:02 UTC#6
just to make sure the 3g is able to be controlled by the avic unit and it is being charged at the same time?
i just want to make sure before i buy this apple cable
Posted Mar 04, 2009 · 04:49 UTC#7
Yes.
