XM addon for F900BT
By whit27 · Dec 28, 2008in General💬 22 posts👁️ 3,468 views
Posted Dec 28, 2008 · 16:51 UTC#1
F900BT needs an external xm module. I have a D2 currently in my truck with an XM addon... Does any one know if that will work on the new F900BT or do I have to buy a new XM Module also??
Cheers
Whit
Posted Dec 28, 2008 · 17:16 UTC#2
You didn't post what the model number is of the one you have now so its impossible to say. Easiest thing to do will be to order the new F series and see if your existing XM interface works.. if not, order the replacement.
Posted Dec 28, 2008 · 17:28 UTC#3
GEX-P10XMT is what I have currently.....
Whit
Posted Dec 28, 2008 · 17:59 UTC#4
I think the model you posted is the XM tuner with NavTraffic. XM NavTraffic doesn't work with the F series so I'm not sure if that tuner will be compatible. I would suggest just cross your fingers and hope for the best.
Posted Dec 28, 2008 · 18:03 UTC#5
I don't have the Navtraffic Unit... Its just the Standard unit...
Posted Dec 28, 2008 · 20:10 UTC#6
It will work fine for music. No traffic though
Posted Dec 28, 2008 · 20:23 UTC#7
So just to spell it out.
Will the GEX-P10XMT work on the F90BT for music only? The reason I ask, I am replacing a failed D3 with an F90BT.
I am going to try but it would be nice to know ahead of time if I am wasting my time trying.
Posted Dec 28, 2008 · 22:15 UTC#8
Did you even read my post?
CamelTowing Posted: Sun Dec 28, 2008 12:10 pm Post subject:
Posted Dec 29, 2008 · 03:27 UTC#9
I read your post, so you have personally made the GEX-P10XMT work on the F90BT ?
Posted Dec 29, 2008 · 03:47 UTC#10
Sure have
Posted Dec 29, 2008 · 04:30 UTC#11
Camel,
Thanks... If the XM Module is plugged in can the Ipod cable still be used on the 900bt?
Whit
Posted Dec 29, 2008 · 05:25 UTC#12
Yes, XM is p-bus. Ipod adaptor is RCAs and USB
Posted Dec 29, 2008 · 05:27 UTC#13
Thanks again for the answers.... I was seeing somewhere that there is a Pbus Ipod adapter for the F series... I am guessing that is not the one I want to buy?? Since the XM mod will take up the Pbus slot
Posted Dec 29, 2008 · 05:30 UTC#15
What is the USB connector for? on this adapter
Posted Dec 29, 2008 · 08:03 UTC#16
To control the ipod
Posted Dec 29, 2008 · 09:33 UTC#17
You can also plug in a USB flash drive for playing music/video files or uploading files including custom splash screens.
Posted Dec 29, 2008 · 22:56 UTC#18
Ipod's don't have USB connections on them. They have that custom Mac connection that is on that cable. So what are you plugging the USB part into?
Like the other person said is it just there for USB drives for Movies and additional Music?
Whit
Posted Dec 29, 2008 · 23:07 UTC#19
Whit
The Pioneer Ipod cable is attached to the F series via a USB AND RCA's.
One one end you have the Apple connector (goes in to the Ipod) on the other end you have a USB connector (male) and RCA connectors. It is my understanding that the USB is used for charging the Ipod and controlling it, where as the RCA's are strictly for media transfer.
Look at the cable that was posted a few posts back... That should explain it.
Posted Dec 29, 2008 · 23:09 UTC#20
I got it now... There is a USB port on the back for the cable... Makes sense so it can charge...
Thanks for the help guys..
Whit
Posted Dec 30, 2008 · 01:07 UTC#21
AVIC-F90BT comes with the ipod cable ;).
Posted Jan 11, 2009 · 05:40 UTC#22
Just wanted to confirm that the F90BT and GEX-P10XMT work together to allow you to get XM music only, no traffic (no data port on the F90BT). I activated it tonight with my new F90BT and it's working great.
