O7 Hummer...D3/XM/Bluetooth. The unit has the black yellow just grounded directly from the head, not plugged into the module.?? Everything worked ok until I put the BTB200 in. It recognized phone once but will not again. Parking brake wire is not present at plug either(down behind unit?) Real HACK job. Most suggestions here are that without a correct bypass it is it or miss.
The instruction to move bk/yel up to the open hole doesn't work because it's not there. What does that empty hole actually connect to on the Delphi plug side?? AND is it absolutely necessary?
BT lights up and allows me to try a connection/search etc. It just will not pair.
XM/Radio/Nav work fine still, just want the BT to work. ![]()
