Bypass Help
By rmv42158 · Sep 25, 2006in Problems/Troubleshooting💬 6 posts👁️ 1,708 views
Posted Sep 25, 2006 · 18:17 UTC#1
Ok, I'm new so im sure you are all sick of this, but i need help if possible. I grounded the E brake wire to a metal screw and well as put the blue ant wire to another screw after putting it in the empty spaces. I still get the warning screen that says my parking brake wire is incorrect and i cannot operated some things on the nav screen unless im stopped. please help.
Posted Sep 25, 2006 · 18:20 UTC#2
What unit? Did you reset the system?
Posted Sep 25, 2006 · 18:58 UTC#3
it is a avic d2, i did it all without the system to power. Do i still need to reset? if so how do i?
Thanks,
Posted Sep 25, 2006 · 20:36 UTC#4
There is a tiny button, like a period, on the front of the unit, maybe under the face. Press it.
Posted Sep 26, 2006 · 00:08 UTC#5
also make sure the wire you added to the harness is seated completely in the harness.
Posted Nov 08, 2006 · 14:15 UTC#6
this is the prob i had when i did bypass. didn't realize the 10th unused pin is actually larger diamter than other pins, so the wire didn't really stay put... it kept sliding out. only when i looked at it carefully i noticed this and made the wire "wider' to accept the larger pin.
