N2 with gex-p10xmt
By nahrah · Dec 29, 2008in XM/Sirius/HD Radio and Traffic Receivers💬 3 posts👁️ 1,394 views
Posted Dec 29, 2008 · 07:28 UTC#1
I just receive my gex-p10xmt and getting ready to install it to my N2 and have a question. I've search and found a similar topic but still doesn't answer my question.Can someone confirm if I have to hook up the power wires to the xm unit? Because on Crutchfield it states:" Power Wiring: If the unit is connected with an IP-Bus cable, it is not necessary to connect the red (+12 volts switched) power lead. The receiver may not work properly if the IP-Bus cable and the red power lead are used together. The Installation Manual incorrectly states that both leads should be connected."
Posted Dec 29, 2008 · 08:05 UTC#2
You still have to hook up the yellow power and the ground
Posted Dec 29, 2008 · 18:16 UTC#3
Thanks! Just got done installing now
