D3 Nav Arrow problem, may be quick fix
By Extent · Dec 30, 2008in Problems/Troubleshooting💬 10 posts👁️ 1,398 views
Posted Dec 30, 2008 · 02:58 UTC#1
Ok heres my problem, i recently installed my D3, everything works, nav works, except i constantly have to "modify current location" not because the aarow is in the incorrect location, but because it is pointing in wrong direction. I can move the aarow in the correct location, and usually within a few miles it will start to be pointing off to the side a bit, and eventually will be pointing enough in the wrong direction that the unit doesnt recognize were i am. This may be an easy fix for some of you, but i dont know whats causing it, didnt know if theres a software update for the D3 or something but im confused, any help appreciated.
Posted Jan 02, 2009 · 06:01 UTC#2
bump!!! please any suggestions? need help!
Posted Jan 02, 2009 · 07:11 UTC#3
Try clearing out the learning status and let it re-learn
Posted Jan 02, 2009 · 21:30 UTC#4
how do you do that? sorry if thats a dumb question i just got it not long ago, im still learning
Posted Jan 02, 2009 · 22:06 UTC#5
Its in the hardware info screen. Manual will have more detailed instructions
Posted Jan 03, 2009 · 02:13 UTC#6
My D3 was the same way, cleared and re-learned still same issue. My Nav antenna wasn't facing straight and the direction it was facing is the same the arrow would point. Faced it straight and now the arrow is correct. I don't know if this is normal but this is what happened with mine for some reason
Posted Jan 03, 2009 · 02:28 UTC#7
wow i bet thats whats happening with me, i didnt even know there was a specific direction the antenna needed to point. Which way is it supposed to point? the cord going into it should point to the front of the car or the rear?
Posted Jan 03, 2009 · 03:03 UTC#8
where the cord goes in is the back, let us know if it works because I have been seeing a lot of these threads
Posted Jan 03, 2009 · 04:58 UTC#9
alright ill let you know if that fixes it! that would also make a lot of sense because the way the antenna is on right now, the cord is on the side
Posted Mar 20, 2009 · 20:37 UTC#10
I had the same problem and fixed it today. Push menu button then settings then hardware info, then 3D calibration. Click on each item on left and press clear for each of them. This should fix it.
