Running Z1 on Car Battery for How Long?
By Tasha · Sep 25, 2006in General💬 13 posts👁️ 2,495 views
Posted Sep 25, 2006 · 20:10 UTC#1
So, any thoughts on how long we can run the Z1 on a "standard" car battery before the car does not have enough power to start back up? Yes I know there are a lot of variables, but....anybody cause themselves a problem yet?
Posted Sep 25, 2006 · 20:24 UTC#2
That would depend on how many other things are also running off of the battery at the same time, like amplifiers,dome lights...etc. Also, batteries have a fairly short lifetime depending on how often you drain it down and charge it back up again.
Posted Sep 25, 2006 · 22:48 UTC#3
well stock batteries are good enough to hold z1 playing for solid 4-6 hours without a problem. (maybe even more, but it depends on the set-up you are running)
I recommend going with yellow top Optima battery if you really need the juice. I have about 1600w of power consumption (speakers/sub), and the optima does its job wonderfully.
Also the main misconception about car batteries, your car alternator is not designed to charge the battery but only to maintain it, so dont go crazy draining the battery (unless u have an optima)
Overall, enjoy the z1 :)
Posted Sep 25, 2006 · 23:39 UTC#4
The Z1 draws about 1.5 amps when it's running, maybe up in the 2 amp range-ish.
1600w of power consumption? Your stereo draws over 100 amps? Are you sure?
Or do you mean that your amps and all say x# of watts and you are just adding them up? Those are always a little "ambitious" of measurements.
The Z1 all by itself is in the 30w range maxed out.
Either way, I wouldn't run the Z1 off battery only for too long. I did for about 6 hours and it drained my new battery down so low it wouldn't start the truck anymore.
Posted Sep 26, 2006 · 00:15 UTC#5
Don't run the Z1 in a new Mustang WITHOUT having the battery being charged at the same time...
I managed to get *maybe* 3 hours out of it before I lost ALL power
Posted Sep 26, 2006 · 03:28 UTC#6
I have a custom 8 speakers system with 2 12" eclipse subwoofers...ranging about 400RMS.
And again I suggest race & show proven Optima Yellow Top...these babies are amazing.
Posted Sep 26, 2006 · 03:39 UTC#7
Sounds like a hot system, but I looked up the specs on those batteries, and the best battery they have is 55ah. Which is pretty good. I don't think those are bad batteries. They are probably very nice.
But, with a 12.5 volt system 1600 w is 128 amps. Which means that if you turned your car on (but did not start the engine), and played your music, your battery would last less than 1/2 hour. Is that true? If so... wow, that is a lot of juice.
My guess is that is those numbers on that equipment is max possible output and usually those are a little ambitious. Just my own opinion. Maybe your car's yellow top battery does only last 20 minutes playing your stereo.... if so... wow, pretty cool!
Posted Sep 26, 2006 · 22:13 UTC#8
I never run the battery hard without the engine running, I have special pulleys and a bigger alternator to provide the juice...and yeah, you are right, I would of never maxed out...that will be unbearable and unreasonable....the numbers I gave was for figurative speaking, as yes, it is possible.... so you can stop now :)
But I do have a nice system....plus my whole car is dynamatted so its sounds sweet.
Since you are the genius of Navis, quick questions, I really need the ATT or Mute button...reason is not for me, but for the cops....looking for a play/pause on the screen is not fast enough....so its holding the AV button...installing that hardwired steering wheel remote, do i have to take my airbag out to properly install it?
Thanks for your input! :)
Posted Sep 26, 2006 · 23:45 UTC#9
Sorry. :) I saw 1600w of power consumption and unless your wire gages were 00 if it really drew that kind of power, it would melt your wires. I think the power wires would need to be 1/2 inch to 1 inch thick. I did some quick math and couldn't believe the numbers. Sorry, I'll turn off my brian and stop doing math :D
As for this, I don't know. I would guess not. Many people have installed these and I would be willing to bet no one took out their airbag. I haven't done one personally, but it goes to the outside ring of the steering wheel not the center.
Posted Sep 27, 2006 · 01:55 UTC#10
Thank you for the info, I will order one....
And do you really think I would run stock gauge wires? :) common dude.
Let me order the remote. eBay should be safe, right?
Posted Sep 27, 2006 · 02:29 UTC#11
ebay is only as safe as the specific person you order from. It's hit or miss. I have had excellent luck on ebay over the years (my account dates back to 1999).
Posted Sep 27, 2006 · 02:47 UTC#12
Sounds good, I'll go with ebay. I apologize for bugging you, but will it be possible for you to take a few photos of the steering wheel control installed? Im just curious how a wired remote holds up on the steering wheel.
Have a good night and a pleasant day tomorrow Sir Ducatiboy.
Bye bye.
Posted Sep 27, 2006 · 11:14 UTC#13
I don't have one, but I think this is one of the steeringwheel remotes:
http://www.autotoys.com/x/catalog/PIONE ... p_600.html
You put that band to the left around a steering wheel.
Someone here might have posted a pic of their setup with one, but I don't remember where.
