Is there a f90bt navi bracket for getting rid of spacing ?
By oxyi · Jan 01, 2009in General💬 6 posts👁️ 941 views
Posted Jan 01, 2009 · 00:50 UTC#1
I installed the F90bt on my mitsu evo, since the navi is smaller, therefore I have gap all around my navi, hence I was wondering do they have a outter navi bracket or some sort to cover up the spaces ?
or is there any DIY solution ?
thanks !
Posted Jan 01, 2009 · 00:52 UTC#2
I had to fashion my own for my Nissan Altima; try looking for a double din spacer ring.. basically its a piece of plastic that you trim to fit.
Posted Jan 01, 2009 · 01:08 UTC#3
my brother in law has an 2008 nissan altima and they had a dbl din kit for that car. It fits perfectly.
Posted Jan 01, 2009 · 01:38 UTC#4
either he has manual climate controls in which case Nissan has a perfect dash kit
or he has automatic climate controls and bought the tacky-ass metra / scosche kits which are tacky-ass and do not match
obviously I wouldn't have fabricated my own trim pieces if I didn't have a choice; see the spaces one each side of the headunit on the pic below:
Posted Jan 02, 2009 · 19:42 UTC#5
Here is what it looks like in my car... it is so hard to find a spacer for mine.. [/img]
Posted Jan 04, 2009 · 14:12 UTC#6
The metra kit to install double din in the Vibe/Matrix has exactly the kind spacer you're looking for, and it's under $20. it sits around the DDin unit and sits out about 1/2" on top and bottom, and an inch on the sides.
It might need a bit of additional work, but it'd look a lot better then the space.
