Help in changing the size of the 3D arrow.
By Jascias · Jan 01, 2009in Hacks/Mods💬 8 posts👁️ 1,499 views
Posted Jan 01, 2009 · 17:13 UTC#1
Finally got back into town (was on 4 month leave), and would like to get back on finishing my mod. Can someone point me in the direction of the post that gave a how to change the size of the original 3D arrow? I could have sworn I saw it some months ago. Checked the faqs, and couldn't find it in a search.
Posted Jan 01, 2009 · 22:06 UTC#2
SYS.TXT:
3d_scale_carmodel=1
3dcarsizemin=4000
3dcarsizemax=6000
3dcarsizemul=60000; adjust numbers as desired.
Posted Jan 02, 2009 · 08:59 UTC#3
Hi Boris,
I noticed that you keep refering to the sys.txt file, but I found that most of the 3d_ variables is also set in the pioneer.ini - at least in the european version of the F900.
What is the difference between these two files?
Posted Jan 02, 2009 · 13:44 UTC#4
Just the priority, basically. pioneer.ini has defaults specific to pioneer, while sys.txt has default settings specific for this particular install. Changing sys.txt is easier since it is not inside an archive....
Posted Jan 02, 2009 · 15:59 UTC#5
Boris do you know if anyone has found a way to apply rotation upon turn to custom car images in place of the 3d arrow so when you make a turn the image actually turns as well. Im still going off of Stephanie's original instructions for 3d arrow replacement where it wasn't possible.
Posted Jan 03, 2009 · 06:12 UTC#6
Not that I know...
Posted Jan 03, 2009 · 11:41 UTC#7
SYS.TXT:
3d_scale_carmodel=1
3dcarsizemin=4000
3dcarsizemax=6000
Thanks alot boris. Which one of these would I change to, lets say, just make it skinner but leave the same size? I know I have to do trial and error, but it would really help to have a starting point.
Posted Jan 03, 2009 · 20:46 UTC#8
I don't think yo can make it _skinnier_ (i.e. compress in one direction). Only proportionately smaller. To change shape we'd need a different MDL file...
