You didn't read my thread correctly.
My iPod Touch doesn't work, I've gotten iPod Nanos, iPod Videos, iPod Minis to work fine. The problem is not my connection, its Pioneer and the lack of integration with the iPod Touch.
My question now is, how can I use the auxiliary input or the RCA jacks to hook up my iPod Touch without integration, because it's quite clear integration is not going to work.
e39m5
Your thread is not at all clear, you seem to be talking mostly about using the 3.5mm jack to connect as an auxiliary input on your old units, and indeed, the ipod touch, and any ipod, you can just connect the 3.5mm headphone output to the minijack on the front of the AVIC and choose EXT2. This is a simple analog choice, and the Pioneer has no idea what device is plugged in, if your ipod touch isn't working in this manner, there's a problem with the ipod.
The ipod touch is about as close a relative to the iphone as there is, and the Pioneers are one of the rare car units that don't mind the iphone connected, and they even list the ipod touch as compatible, so it's not like none have ever worked in the history of this head unit.
The fact that nothing is ever working on unit would point to a setting being wrong, or the cables not being connected properly, just last week there was a user that had the R/W/Y RCAs connected correctly but had never connected the male and female USB together, without us being able to see what you see, there are limits to what we can help with, and there are some core assumptions we have to make, and a large one is "the cables are installed correctly"
You don't even say if when you did hook the ipod up via what we're all assuming is the right cable with both USB and RCA, if it's just that you didn't get sound, or that you didn't get sound AND you couldn't get ipod control on the head unit. Sound comes in via the RCA inputs for ipods, and control is handled over the USB. So BOTH are needed to be hooked up and the proper setting under AV1 needs to be enabled.
The description of "nothing at all works with any of my ipods, front jacks OR rear" suggests there's something bigger wrong, and a review of the settings for the various inputs, and then physically triple checking the cables to the rear might be beneficial.
Diane
