XM install
By HolyTrojan · Jan 04, 2009in Problems/Troubleshooting💬 6 posts👁️ 1,010 views
Posted Jan 04, 2009 · 06:15 UTC#1
Can I just splice the pwr on my bus cable to the pwr going into my f90bt? It'd be yellow to yellow but the whole thing doesn't sound right to me. Wouldn't it draw too much power and if so, what do I hook it up to?
The instructions on the xm module suck!
I know the pac module splices into the ignition wire but . . . .
I dunno, HELP!
Posted Jan 04, 2009 · 14:22 UTC#2
for my sirius module, I used the "system remote control" wire rather than the constant +12v source and I have had no problems
Posted Jan 04, 2009 · 18:44 UTC#3
Thanks for the idea, if I were to do that could I splice into that wire and still get my subs to turn on?
Posted Jan 04, 2009 · 23:19 UTC#4
I really don't think that it's a good idea to use the remote turn on wire to power any other device. It is meant to be a low amp supply just to signal the amps to turn on. People with more than one amp usually just use it to turn on a relay which in turn turns on the amps.
Posted Jan 05, 2009 · 03:17 UTC#5
That sounds right to me too. Is the module designed to be spliced into the power of my head?
Posted Jan 05, 2009 · 04:43 UTC#6
Yes, it will be fine
