Bluetooth won't connect
By twomed · Jan 05, 2009in Problems/Troubleshooting💬 3 posts👁️ 1,015 views
Posted Jan 05, 2009 · 00:39 UTC#1
Bypass is now correct and solid...plays DVD's. When I go through the BT search connect...phone (VZN LGVX8300), it ID's the BT2, pair, enter 0000, does not pair, have tried reset on BT200, BT search for phone "no connection"....mutiple tries, same results, arrrgh. Another thread shows this phone as one that works.
Separate issue...can I do a reset on D3 without the security word. I bought this Hummer, sent notes to previous owner, no reponse, dealer no help. Really afraid of that security lockout because Nav and XM are great.
Posted Jan 05, 2009 · 18:48 UTC#2
Go in and try and set your own security word. If it works, you know the password. If it doesn't, you can send it in to be reset now and try and get reimbursed from the place you bought the car
Posted Jan 08, 2009 · 19:22 UTC#3
Regarding the PW issue, figure it out soon. Once you lose power to the radio (i.e. battery dies, truck goes in for service), you're gonna need it.
I had better luck pairing my LG VU920 by finding it with the HU, as opposed to searching for BT devices by phone. Just make sure the phone is set to BT "visible", then "search for devices" with the HU...then follow the prompts, enter the code, connect, then register it in phone slot #1.
