ipod issue
By badabing1551 · Jan 05, 2009in Problems/Troubleshooting💬 3 posts👁️ 969 views
Posted Jan 05, 2009 · 03:15 UTC#1
i've connected all the cables for the ipod but I am only getting sound out of the front right speaker. is there a way to fix this?
Posted Jan 10, 2009 · 04:22 UTC#2
To make sure I understand you correctly, are you only getting sound out of the front right speaker when the iPod plays? Or when you play the radio, DVD, etc... as well?
Posted Jan 10, 2009 · 17:04 UTC#3
Search the forum. Common problem and usually the Pioneer iPod cable. Get the apple version of the iPod cable, the Pioneer cable is made in China with no obvious attempt at quality control.
I went through 2 before searching the forum and finding this happens a lot. I have a Pioneer cable that works now but wonder if it will hose me at some point and I will be back in the dash again.
The Apple cable is a much better value and you get a wall charger to boot for the same money as Pioneer.
Now if you are having problems with a dead channel other than the iPod you probably have an issue with connections and something is loose or not connected properly.
