thrang said:
I'm a bit confused - when I had the unit installed, I instructed the installer not to attach the parking brake, and not to ground it - just tape the end up and leave it free.
While I have your flasher, I haven't installed it yet, so I've still been manually flashing the lights. When I start the car, I ALWAYS get the parking brake warning, but the flashing bypass ALWAYS works.
Well for this to happen, someone grounded the parking brake and drove around with it grounded. I don't know if you did that first or your installer did that, but someone did and didn't reset it after pulling the ground.
thrang said:
Is it likely that it was never "reset," so perhaps the installer left the wire as instructed, but I'm getting the message anyway? Yet the bypass functionality is there - I've driven upwards of an hour, and I've never lost the functionality.
If you have manually flashed the lights and it was bypassed and then didn't and realized it was not bypassed, then yes, he probably pulled the parking brake wire from ground and didn't reset the unit.
thrang said:
BTW, there are multiple "resets" for the Z1 - which one do I perform to clear the message? And what else does this reset clear/wipe out?
reset the unit by pressing the little recessed button to the right of the eject button.
