static from one speaker.
By mkelias11 · Jan 06, 2009in General💬 4 posts👁️ 1,108 views
Posted Jan 06, 2009 · 02:59 UTC#1
amp is well grounded, but i start to get static from one speaker at random times, what can it be, i switched the rca at the amp, and it just switched from static the left to the right.
Posted Jan 06, 2009 · 03:41 UTC#2
you tried switching rca's so the static moved from left to right.. did you check the rca connection from the head unit to the amp?
Posted Jan 06, 2009 · 03:48 UTC#3
yea they were routed correctly and they are good quality!
Posted Jan 06, 2009 · 16:20 UTC#4
You switched the RCA's at the amp, left and right, and the static switched. Did you try running NEW rca's loose to your amp to see if the problem goes away?
Good quality RCA's can still be defective.
