Strange Navi D3 problem
By prnit · Jan 06, 2009in Problems/Troubleshooting💬 3 posts👁️ 864 views
Posted Jan 06, 2009 · 15:58 UTC#1
Hi I have a D3 Pioneer system, everything works fine exept..hmm..I am using the unit for about a week, the navigation worked fine but now everything works fine with navi I can see where the car is, zoom it, push it go home and so on but the address search and POI search doesnt work..when I push the go to address button there is no option to choose and the navigation is coming by itself to normal map view mode....I am not using the orginal navi Map (burned verbatim) but still the problem didnt existed before..any ideas? by the way...if someone wants to download the East European map..here is the link http://linksave.in/13445726844933d5754c122
Posted Jan 06, 2009 · 19:38 UTC#2
Try a real disk and see if it works correctly
Posted Jan 06, 2009 · 21:15 UTC#3
I figured it out, strange thing...I recorded a new disk and it works perfectly...so new experience..even if sometimes a recorded disk works and everything looks ok...not every function can work... :roll: so before you use it try everything in navigation program...best regards prnit
