I installed it in Nov '08 and it worked fine with firmware 2.0 installed.
Then in Dec '08 when the snow came and sub zero temperations the AVIC became sluggish with slower boot up and the touch screen is not as responsive. I have to touch it several times to get it to work.
The Maps on the GPS would randomly freeze and I have to tap on the MAP button to unfreeze it.
I normally set the GPS to display in 3D mode but at random the display would switch to 2D by itself and I have to click on the 3D to revert back. This happens many time on a single trip.
Also most times when I reached my destination the AVIC does not cancel the trip and kept going even after it had announced that "you have reached your destination". This is very annoying as I have to then manually cancell the trip.
By comparision my Garmin nuvi 760 works flawlessly as well as my OEM Navi on my Honda Accord.
Had I known that the AVIC is not up to par with the others I would not have bought it.
As such I am quite disappointed with it.
I should have chosen the Kenwood unit which comes with a Garmin GPS.
I hope that the above flaws can be corrected with another firmware update.
