why am i afraid to install my 90bt?
I'f you've installed radios before, you have no reason to be worried. Other than running an antenna and a mic (and the VSS wire if you choose to do so), There's nothing different. Bypass is also very simple.
When I had my D3 with BT module and xm module it was a little more complicated... But this unit has everything built in to a single unit. As was said earlier, plug in and run the wires for the mic and the GPS and your done. Everything else is exactly as youve done before only with a little bigger case.
Good luck and let us know how it goes!
T
thanks guys.....im unsure at this point if tryin to trace the wheel speed sensor up to the ecu is worth it, i guess ill see how it goes without and go from there........i appreciate the reassuring words
settles my nerves down.........
Take your time and double check your wirings and you should be fine.
I personally would have been worried about having issues with the F-series but hopefully the update fixed all that.
Thats why I have the Z3 (knock on wood).
make sure to buy your vehicle specific wiring harness and that will save you tons of trouble
Take the time to find your VSS wire, it makes your unit more accurate. Give me some more info on your car (who makes the redline vue?), and I'll see if I can find the location of your VSS for you.
Its a Saturn Vue Redline edition. 18" wheels 3.5 v6 AWD with body appearance package.....so basically its a "blinged up" Saturn Vue ![]()
i am pretty sure its the correct harness talked with the people from sonicelectronix concerning my 6 speaker system and factory amp/sub but the only harness they had was for a 4 speaker so ill just junk the factory sub/amp and put my old sub and amp in.
Ok, here's what I found. Besure to test it prior to connecting it to make sure it's correct.
VSS WIRE Purple/white At ECM pin 18
its a 2005 btw not sure if it makes a difference.....and im going to sound like a total NEWB but whats the best way to test to make sure? thanks madsonp
You'll need a digital multimeter (can be had fairly cheap at an auto parts store or radio shack, $20 $30 or so) - set it on AC voltage and seeing if it fluctuates when the car is moving (VSS wire sends pulses as the speed indicator)...
Actually, I've never tested it - just made sure I located the right color-coded wire from the right location - seems to work 99.999% of the time from everyone I've ever talked to.
I knew it was an 05 from your first post. I only suggested testing it because I'm not 100% positive on the accuracy of the info.
