F700Bt Video
By Dragonrep · Jan 08, 2009in General💬 6 posts👁️ 1,521 views
Posted Jan 08, 2009 · 02:00 UTC#1
I have a DVD player installed in the rear seat of my truck, with video and audio outputs. Could I run this signal to the F700 and display the video and audio through the AV Source (I-Pod) connection?
Posted Jan 08, 2009 · 03:04 UTC#2
yes turn av1 to input and not ipod and sure.. if you want both you need 3 y splitters
Posted Jan 09, 2009 · 02:56 UTC#3
I figured that's what I would be looking at from reading the posts, but I wasn't sure the video would be compatable.
Posted Jan 09, 2009 · 03:35 UTC#4
What is the AV 2 source listed in the source setup section. It can be toggled to 'off' and 'video'? When I look at the back of the unit there is only one set of RCA connectors though.
Posted Jan 09, 2009 · 03:43 UTC#5
AV2 is the port on the front of the unit.
Chapter 2 of the manual with the diagram of what parts are where shows it pretty clearly.
Posted Jan 09, 2009 · 03:46 UTC#6
:oops: Guess I need to spend some time with the old manual...thanks!
