f90bt in 05 f250
By 05 6.0 fx4 · Jan 08, 2009in Problems/Troubleshooting💬 1 posts👁️ 520 views
Posted Jan 08, 2009 · 16:30 UTC#1
Sup install gurus,
I have been searching and searching all over these forums, not to say its not here, just ready to install and im still unsure. First off I moved the mute wire to the other location, so now what do I do with the mute wire, ground it? Also im not sure, but I believe the black with gray on the factory harness is the vss wire? Also the reverse wire, is that the black with pinkish purple stripe off the fuse panel under the dash on driver side? And for the e brake, do I just ground that off the ground (black wire)? And last can I just put the nav antenna on top of the head unit? Someone please help, im dying to get this thing installed.
